In the properties of a dimension you can enter text that shall be shwon instead of the actual dimension.
AutoCAD understands certain control characters, e.g. <> for the value or \X for vertical spacing.
I am looking for a comprehensive list of all control characters that can be used.
Can anybody help?
Solved by Victoria.Studley. Go to Solution.
Hi Peter,
You may find the following articles about control codes and special characters helpful:
Control Codes and Special Characters Reference
Text Symbols and Special Characters Reference
Special Unicode Characters Reference
About Using Unicode Characters, Control Codes, and Special Characters (VBA/ActiveX)
About Special Control Characters in Command Macros
