Hi Kyle -
The system defs aren't pulled from any of those files. Those files are there
as additional / backup style definitions, but are not pulled in
automatically by the program. If you want to get system defs in existing
drawings you should be able to simply insert a drawing with the system defs
in it into the current drawing.
jason
"Kyle Bernhardt" wrote in message
news:CAFCA16EFD18EB26A779104B80A3118E@in.WebX.maYIadrTaRb...
> I have created a template file that defines all the necessary systems for
my
> BS objects, and when our users start a new drawing with the template all
the
> systems come in correctly. The problem is that when you start using ABS
on
> an existing CAD drawing without the template, these systems do not exist,
> only the default ABS systems. I see that there is a file under "Documents
> and Settings\...\enu\Styles\Imperial\" called "Pipe System
Definitions.dwg".
> Here the default systems are defined. Instead of changing this file on
> every computer, I'd like to have a version of this file on our network
that
> is referenced by every computer. Even better, I'd like to move the whole
> "Styles" folder to the network. I do not see this folder in the search
> path, so I cannot simply move it and change the path, where is the
reference
> to the path where these systems definitions files are located? I need to
be
> able to change this setting.
> Kyle Bernhardt
> Mechanical Engineer
> Dagher Engineering
> 29 Broadway
> New York, NY 10006
