AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
custom tag
2 REPLIES 2
TheH
922 Views, 2 Replies
custom tag
I had my new diffuser tag all worked out. Exploded an air terminal device tag, moved things around, change text styles, changed layers from 0 to G-anno-std-text-tag .  I did the definetag command and when I select the insert point, the tag goes to about 1/10 of it's size.
Is there a variable that I accidently turned on that is rescaling the tag as it is beign created?
2 REPLIES 2
Keith.Brown
in reply to: TheH
Before you redefine the tag, you need to make sure that your annotation scale is set to 1:1 and that your text is non annotative and set to 1" tall.  This will make it appear correctly once you create a tag.
TheH
in reply to: Keith.Brown
Thanks. That was the problem.
”Boost
