AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Crossing lines
2 REPLIES 2
jseward123
356 Views, 2 Replies
Crossing lines
Hi, I'd like to know if there is a masking solution to crossing lines.
See attached image. Thank you.
2 REPLIES 2
jseward123
in reply to: jseward123
Currently I am using polygons applied to the WIPEOUT command to mask the intersection of lines crossing arcs. That is the simplest solution.
wkuehn
Wipeout like you mentioned would be the easiest if you truly want to "mask" it. Otherwise just run BREAK and separate it making two line entities. Set what you want to a frozen/off and/or no plotting layer.
”Boost
