AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Crosshair color in 2010
2 REPLIES 2
T_nichols
440 Views, 2 Replies
Crosshairs blend in with the background. The pickbox also is virtually nonexistent against the background. I have tried changing the colors of the crosshairs in the options and have had no success or the result is temporary. This problem did not exist in earlier releases because the crosshairs or pickbox turned to a different color than the object or the background that you were hovering over.
2 REPLIES 2
in reply to: T_nichols
I'm having the same issue. A "solution" is to use a 2D visual style in your viewport, but if you are in a 3D viewport this problem may raise its ugly head.
Dyna1
Thanks for the advice. That works just fine as long as you want the visual style to be in wire frame. Hopefully Autodesk will get their act together.
”Boost
