AutoCAD MEP General Discussion
kadmonkee
Message 1 of 2 (396 Views)
Creating a dynamic block for a duct riser
396 Views, 1 Replies
05-01-2012 09:28 AM
I would like to be able to create a dynamic block for a duct riser that can accommodate various sizes (ie: 12x12 , 16x28)
what I have tried is a stretch parameter/ action but the hatch is not cooperating.
Any suggestions please
this will need to have visibility states to allow for supply , return and exhaust as well as up and down features.
Thank you
Employee
gregg.stanley
Message 2 of 2 (366 Views)
Re: Creating a dynamic block for a duct riser
05-04-2012 09:20 PM in reply to: kadmonkee
Rise and Drops for AMEP objects are controlled by the rise drop styles in style manager under each object type. The rise drop styles use acad blocks and are scaled to fit the size of the duct. You can assign different blocks to each condition, rise / drop, tee, elbow, etc. You can also save the styles and assign them per each system. to allow you to have different systems with unique symbols. The rise drops styles may not support dynamic blocks, honestly never tried it, because the code scales the block in both x and y to match the size. Solid hatches are supported as well as centerlines. Please refer to help on rise drop styles for more information.
Thank you
Gregg Stanley
Gregg Stanley
QA Analyst
AEC
Autodesk, Inc.
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
