AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
creating a custom tag for duct.....
4 REPLIES 4
cedwards777
1501 Views, 4 Replies
i have been having issues in my attempt at making a custom tag in AMEP for my duct.  I am trying to make a tag that places the size of the duct above the bottom elevation, with the elevation line of text always using "BE=" before displaying the architectual measurement.
can anyone give me any advice on this one?  thanks
an example of what it would resemble
24X24
BE=10'-0"
4 REPLIES 4
Keith.Brown
in reply to: cedwards777
You might try following this series that I did on creating a duct custom elevation tag.  You can start the series at the link below.
http://www.cadengineeredsolutions.com/autocad_mep/creating-a-duct-elevation-tag-part-one/
I have attached a dwg where I made such a tag.  I just used the default property definitions that are in DuctObject and modified the Bottom of Duct property definition to read what you wanted.
Pothman
You can also find information on how to create a custom tag here:
http://knowledge.autodesk.com/support/autocad-architecture/troubleshooting/caas/sfdcarticles/sfdcart...
Dave Pothier
in reply to: Pothman
Neither of these methods seem to work for the 2015 version. Has something changed about how you get into the style manager? It isn't under the manage tab any more and the command promt isn't recognized 😞
Keith.Brown
Both of these methods should work just fine in 2015. I just tried it.
It sounds like you are in AutoCAD and not MEP. What happens when you try another command like duct add or pipe add?
”Boost
