AutoCAD MEP General Discussion
*W, Matt
Message 1 of 3 (157 Views)
Count devices via VBA
157 Views, 2 Replies
11-24-2003 12:10 AM
I want to do a quick count of devices in a drawing
and I want to do it via VBA, but I'm running into a wall on how to do
it.
(I know I can create a schedule, but I don't want
to)
Here's what I have so far...
Public Sub CountDevices()
Dim objDeviceStyle As AecbDeviceStyle
    Dim objDeviceStyles
As AecbDeviceStyles
    Dim aecDB As New
AecbDatabase
    aecDB.Init
ThisDrawing.Database
    Set objDeviceStyles =
aecDB.DeviceStyles
    For Each
objDeviceStyle In objDeviceStyles
If objDeviceStyle.Name <> "Standard"
Then
Debug.Print objDeviceStyle.Name
End If
    Next objDeviceStyle
End Sub
I can't quite figure out how to get the total
count for each "objDeviceStyle".
I know it's something easy, but I'm just gonna
chalk it up to it being a Monday.  :smileyhappy:
Thanks in advance!
Matt W
There are 3 kinds
of people:
  Those who can count, and those who
can't.
*[Autodesk], Hakan Wikemar
Message 2 of 3 (157 Views)
Re: Count devices via VBA
11-24-2003 04:36 PM in reply to: *W, Matt
Hi Matt!
The Code you have produced works fine when it comes
to identifying the device styles that exist in the drawing, imported styles,
inserted or not. However, if you want to scan the drawing of how many devices
there is in it you will need to search through the modelspace or
dictionaries databases. The easiest way (in my experience) is to scan
through the modelspace, you will then only get the devices that are actually
inserted into the drawing. If you look at my VBA project below the header DEVICE
COUNT in the autodesk.autocad.customer-files newsgrop (a part of a discussion I
had about Device Counting in the BS wishes discussion newsgroup), you might find
it useful, it counts the presence of devices and groups them by system and
style.
The basic syntax I usually use is the
following: (Prints the stylename for everey ocurrance)
Dim obj As
AcadObject
Dim aDevice As AecbDevice
For Each obj In
Application.ActiveDocument.Database.ModelSpace
    If TypeOf
obj Is AecbDevice Then
        Set
aDevice = obj
        Debug.Print
aDevice.StyleName
    End If
Next obj
End
Sub
I hope this helps
/Hakan Wikemar
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
drawing and I want to do it via VBA, but I'm running into a wall on how to do
it.
want to)
    Dim
objDeviceStyles As AecbDeviceStyles
    Dim aecDB As New
AecbDatabase
    aecDB.Init
aecDB.DeviceStyles
    For Each
objDeviceStyle In
objDeviceStyles
        If
Then
End If
    Next objDeviceStyle
End Sub
Thanks in advance!
Matt W
There are 3 kinds
of people:
can't.
*W, Matt
Message 3 of 3 (157 Views)
Re:
11-24-2003 09:35 PM in reply to: *W, Matt
Ah ha!!
I knew I needed some kind of an
array.
I took a look at your code in the CF group and
that's exactly what I was looking to do (and then some).
Thanks, Hakan!
Matt W
There are 3 kinds of people:
  Those
who can count, and those who can't.
Hi Matt!
comes to identifying the device styles that exist in the drawing, imported
styles, inserted or not. However, if you want to scan the drawing of how many
devices there is in it you will need to search through the modelspace or
scan through the modelspace, you will then only get the devices that are
actually inserted into the drawing. If you look at my VBA project below the
header DEVICE COUNT in the autodesk.autocad.customer-files newsgrop (a part of
a discussion I had about Device Counting in the BS wishes discussion
newsgroup), you might find it useful, it counts the presence of devices and
groups them by system and style.
Dim obj As
AcadObject
For Each obj In
    If TypeOf
        Set
aDevice = obj
        Debug.Print
aDevice.StyleName
    End If
Next obj
End
Sub
I hope this helps
/Hakan Wikemar
do it.
want to)
Public Sub
CountDevices()
AecbDeviceStyle
    Dim objDeviceStyles As
AecbDeviceStyles
    Dim aecDB As New
AecbDatabase
    aecDB.Init
aecDB.DeviceStyles
    For Each
objDeviceStyle In
objDeviceStyles
        If
Then
Debug.Print
objDeviceStyle.Name
        End
If
    Next objDeviceStyle
End Sub
Thanks in advance!
Matt W
There are 3
kinds of people:
can't.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
