AutoCAD MEP General Discussion
Member
centurymechanical
Message 1 of 7 (1,269 Views)
COPY TO CLIPBOARD
1269 Views, 6 Replies
09-26-2011 12:38 PM
When trying to copy to clipboard there is a error, saying copy to clip board failed.
Mark
shiny.stephen
Message 2 of 7 (1,265 Views)
Re: COPY TO CLIPBOARD
09-26-2011 09:45 PM in reply to: centurymechanical
Which version of AutoCAD MEP you are using? There was a known issue in AutoCAD MEP 2010 which was rectified in web update 2.
Shiny Stephen
Support Specialist
Product Support
Member
centurymechanical
Message 3 of 7 (1,252 Views)
09-27-2011 07:22 AM in reply to: shiny.stephen
We are using 2012.
New Member
anpers
Message 4 of 7 (1,104 Views)
03-22-2012 05:45 AM in reply to: centurymechanical
I get the same error "Copy to clipboard failed"
I'm using version 2012
Any news/tricks on solving this issue?
Product Support
Joshua.Benoist
Message 5 of 7 (1,077 Views)
04-04-2012 06:39 AM in reply to: anpers
Do you have a 3rd party application like Quickpen, CADDUCT or EastCoast CAD?  With a "Proxy Object" in the file, objects cannot be copied to the clipboard.  The goes for Civil 3D objects wo the object enabler as well.
Joshua Benoist, PE
Senior Support Specialist
Product Support
New Member
anpers
Message 6 of 7 (1,053 Views)
04-11-2012 12:44 AM in reply to: centurymechanical
Thanks for the information.
It may be the reason you describe, but I'm not really sure what the file contains since it is a file produced by client and sent to us. I'll be more aware of this next time I recieve AutoCad files.
//Annika
Active Member
Joshlieu
Message 7 of 7 (800 Views)
11-16-2012 03:16 PM in reply to: centurymechanical
Had the same problem and ran across a quick work-around:
In my case I could use the ACAD COPY command (CO) but not the COPYCLIP command (CTRL-C)
I simply copied the whole drawing using COPY and moved off to the side. The resulting copy could be copied to the clip-board without any problem.
I'm using ACAD2013
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
