I have an old template file that was created with autocad 2008 I believe. When I open the Style manager in MEP 2014 the everyhing is blank. I think i read somewhere that it is because it is not an MEP template. My question is, is there any way to update it to be and MEP template?
Solved by VitalyF. Go to Solution.
Use "_adcenter"
1. Open your Autocad template
2. Open MEP template (must be current)
3. Type command _adcenter, go tab "Open Drawings"
4. Navigate through the categories in the left window, select the desired
5. In the right window, select your Autocad style, right click "Add ..."
6. Save MEP template, ok!
Good luck,
Vitaly
...additionally >>
7. Export Layers from Autocad template with "_LAYERSTATE", import to MEP
8. Create or modify the MEP Layer Key Styles from Autocad Layer
9. Import Layout from Autocad template:
a) Opet MEP template right click on layout "Page Setup Manager" > "Import" > select Autocad template
Please use .Accept as Solution and Give Kudos as appropriate. Thank you!
@VitalyF wrote:
Use "_adcenter"
Good luck,
Vitaly
I went ahead and marked this as the solution as the original poster verified that it fixed their issue.
