AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Content Builder - problem adding geometry
4 REPLIES 4
dacamp
547 Views, 4 Replies
I'm trying to draw a custom pipe fitting in the Content Builder and it won't let me draw lines (when adding geometry) if they are too close to existing points (the nearby points will highlight). If I move a bit further away I can draw the line, but then it's too long. The line I'm trying to draw is an inch long, nothing very small. Is there a setting that controls this?
4 REPLIES 4
gregg.stanley
in reply to: dacamp
In content builder scale does not matter since you need to use a dimension or constraint to define the true length of the line. For drawing you can change the annotation scale and Regen to make all the items smaller.
Gregg Stanley [Autodesk]
Gregg Stanley
QA Analyst
AEC
Autodesk, Inc.
Schmit01
in reply to: dacamp
You could also just draw the line longer than what is required then dimension it and then set it to the correct size.
Ryan Smit
dacamp
in reply to: dacamp
OK, thanks. I see what you both mean.
t.vanskyock
in reply to: Schmit01
How do I dimension it to the right size??? Please help
”Boost
