Pick the position of the connector and then use the normal to change the
direction 180 degrees. You can use points to select the normal on screen, or
simply type in vector directions at the command line. If you want the
direction of the connector to be in positive X you can simply select normal
and type 0,0,0 1,0,0. If it's in positive Y then it would be 0,0,0 0,1,0 and
so on.
jason
"jmcfaddn" wrote in message
news:f16abea.-1@WebX.maYIadrTaRb...
> Trying to modify connectors within Content Builder. The command line is
locked on Position/Normal for some reason and will not let me change the UCS
axis orientation. My main goal is to rotate the connectors 180degrees so
that they are pointing away from the mvpart. But with the way the axis
orientation my only options are 90degrees and point at the part.
> What can I do to fix this problem?
> This MVpart library idea is so poorly supported, if it's not any better in
Bldg Sys. 4 then version 4 is going to be as useless as bldg sys. 3.
> Jmcfaddn
