Hello, I've noticed a strange operation of MEP becouse I have a MVpart (a shower) with a piping connector. Sometimes, if I put several of this MVPart in the drawing and try to connect a pipe to the connector, some of them doesn't connect doing exactly the same! I can't draw a pipe connected to this connector. I have try to connect from autside the MVpart to the MVpart, clicking in the "+" sign of the connnector, nothing goes... Has AutoCAD MEP a tolerance parameter to modify trough option or something similar?? Thanks!
I attach an example. Is an MVpart with the connectors defined but when you clik on plus button to gemerate a pipe, it doesn't connect to the connector. Thanks!
