AutoCAD MEP General Discussion
RGD
New Member
RGD
Message 1 of 3 (99 Views)
connecting a pipe
99 Views, 2 Replies
07-29-2003 11:42 PM
I am trying to connect a horizontal pipe to a vertical riser at a particular elevation. It can be done in SW view, but it only grabs the pipe curve. Getting the elevation set requires several additional steps. Can this be done in one operation. It is very time consuming the way I am doing it. Thanks
*[Autodesk], jason martin
Message 2 of 3 (99 Views)
Re: connecting a pipe
07-29-2003 11:47 PM in reply to: RGD
Hi Bob -
Do you know the elevation that you want to connect at, or is it at the end
of the pipe? You should be able to set the elevation in the elevation box
(on the pipeadd dialog) and press the "lock" button to force the elevation.
jason
"RGD" wrote in message
news:f17c46d.-1@WebX.maYIadrTaRb...
RGD
New Member
RGD
Message 3 of 3 (99 Views)
Re:
08-04-2003 02:14 AM in reply to: RGD
Thank you Jason
That works like a champ.
Big help on plumbing and mechanical side
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
