AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
connecting a pipe
2 REPLIES 2
RGD
229 Views, 2 Replies
connecting a pipe
I am trying to connect a horizontal pipe to a vertical riser at a particular elevation. It can be done in SW view, but it only grabs the pipe curve. Getting the elevation set requires several additional steps. Can this be done in one operation. It is very time consuming the way I am doing it. Thanks
2 REPLIES 2
in reply to: RGD
Hi Bob -
Do you know the elevation that you want to connect at, or is it at the end
of the pipe? You should be able to set the elevation in the elevation box
(on the pipeadd dialog) and press the "lock" button to force the elevation.
jason
"RGD" wrote in message
news:f17c46d.-1@WebX.maYIadrTaRb...
RGD
in reply to: RGD
Thank you Jason
That works like a champ.
Big help on plumbing and mechanical side
”Boost
