Hi, a question about connections between panels across different constructs. I'm obviously using a "Electrical Database File" forsharing information between constructs.
In one construct I have a panel general where I connect secondary panels of the same constructs and other constructs. I have no problem connecting all panels that I want of the same construct through a circuit (circuit breaker in panel) but for example, if I try to connect to the general panel another panel of another construct only lets me connect by Feed- thru lugs becouse the connection via circuit breaker in the panel is not available. Also, once I connected the panel of another construct, I'm not allowed to connect more panels.
Any idea for this problem??
