AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Conduit and cable tray disappears after you use orbit.
2 REPLIES 2
Dyna1
409 Views, 2 Replies
When I use the orbit command I have had conduit and cable tray disappear and the only way that I have found to get it to reappear is to undo back to before I used the orbit command. This has happened in 2008 as well as 2009. Any thoughts?
2 REPLIES 2
lifeoriley0
in reply to: Dyna1
Have you tried regenall?
Dyna1
in reply to: Dyna1
I have tried that and it does not work but since then I have found that if you change to 3-D wire frame from realistic and back again the conduit or cable tray reappears. Saving your drawing seems to do the trick sometimes also.
”Boost
