AutoCAD MEP General Discussion
Valued Mentor
dennis
Message 1 of 2 (213 Views)
Checking workflow: Circuiting Mech/Plumbing Equipment
213 Views, 1 Replies
10-14-2011 11:31 AM
I want to make sure I am doing the 'best way'.  I am xrefing in a Mechnical dwg into my electrical dwg that has it's epd defined and running along fine with my lights and recepts.  I want to now circuit up the mech equipment.  I am using the XRef_Edit to pull the equipment directly into my elec dwg, then coverting the equipt to a device, assign the elec connector values and assign it to a circuit.  Is that right?  Seems ugly, but can't see another way to do it.
Employee
martin.schmid
Message 2 of 2 (147 Views)
Re: Checking workflow: Circuiting Mech/Plumbing Equipment
10-31-2011 03:48 AM in reply to: dennis
I've typically seen where one will place a 'junction box' device, and circuit to that.. avoids the ref-edit, convert to device, etc..There's nothing necessarily wrong with what you're doing, but there's no real benefit to copying the equipment into the 'host' elec model.
Martin Schmid, P.E.
Product Manager - Revit MEP
Architecture, Engineering, and Construction
Autodesk, Inc.
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
