AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Checking workflow: Circuiting Mech/Plumbing Equipment
1 REPLY 1
dennis
367 Views, 1 Reply
I want to make sure I am doing the 'best way'.  I am xrefing in a Mechnical dwg into my electrical dwg that has it's epd defined and running along fine with my lights and recepts.  I want to now circuit up the mech equipment.  I am using the XRef_Edit to pull the equipment directly into my elec dwg, then coverting the equipt to a device, assign the elec connector values and assign it to a circuit.  Is that right?  Seems ugly, but can't see another way to do it.
1 REPLY 1
Martin__Schmid
in reply to: dennis
I've typically seen where one will place a 'junction box' device, and circuit to that.. avoids the ref-edit, convert to device, etc..There's nothing necessarily wrong with what you're doing, but there's no real benefit to copying the equipment into the 'host' elec model.
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
”Boost
