Hi Mark -
The view blocks inside the tags work in the same way as a standard AutoCAD
block.
The width factor of the attributes are applied to each instance of the
blocks rather than the block definitions.
If you always wanted the blocks to show this way you should edit the content
drawings, so that they come in with a default width factor of .8.
jason
"Mark_Leaf" wrote in message
news:f180702.-1@WebX.maYIadrTaRb...
> I want light and difffuser tags to use style REGT which uses FONT
Romansp.shx with a width factor of 0.8. Is there an easy way to do this
without exploding the block and editing the attribute text. Changing the
Standard dim style to REGT only changes out the FONT and the width is not
affected.
> Mark
