AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Can't save a drawing when this displays on the screen
3 REPLIES 3
364 Views, 3 Replies
Using AutoCad Mep2014:  Has anyone had this error message(see below) come up when trying to save or saveas or even try to write the drawing to a new drawing??  This only happens when modeling, and not all the time. All i can do is close and reopen.  Any help would be greatly appreciated.  Thanks
3 REPLIES 3
pothied
This is a message that can display if you do not have enough free disk space where you are trying to save the file to. Check to see how much disk space is avaialble (even if it is a network drive) and if it is full, clean up the drive or save to a new location. Please accept this as the solution if this is your problem.
David Pothier
in reply to: pothied
It was on our server and i tried to save to a new location on my 2nd hard drive on my computer and it still would not save?? This error never happened before i started using autocad mep 2014.
VitalyF
We had the same problem with HP server.
Files waiting for their turn to record on the server disk.
RAM on the server must have an additional cache memory module!!!
Ask your system administrator or IT specialist
”Boost
