AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Can't edit fittings within the Properties Dialog box
3 REPLIES 3
Shawn_SunsetAir
743 Views, 3 Replies
I'm sure there's a toggle somewhere for this.  But I can't seem to edit fittings within the properties box.  If I have a transition that's 30 degrees, I can select the angle and make it 15, but it doesn't change or do anything.  If I actually click on the part shown above, I can find the angle and change it there... just not in the first properties box.  Anyone come across this?
3 REPLIES 3
Is there a duct segment (or pipe) connected at either end of the elbow?
Joshua
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Wanted to follow up.
Joshua
Joshua Benoist, PE
Global Services
I forgot about this question, but now that I'm doing some more BIM jobs, it's come back up.  Yes, the problem seems to be when I have duct connected to the fitting.  I can easily modify an elbow or transition if it's alone within the properties dialog box.  But if the elbow or transition has ductwork attached, it won't change.
”Boost
