Is there a way to publish several layout in several diffrent drawings to plt and cal files in one printing session?
I.e. for pdf, select publish choose drawings to be part of sheet and select publish, program creates all pdf
Yes, if you the PUBLISH command. Our firm uses a dwg file with variations of diffrent plotsettings configured in it. When running the publish command we select, publish to, plotter named in page setup. Under Page setup we import the settings from the dwg file and use the plotmethod we want and just publish away.
