Anyone have a 2013 version for this enabler yet.. I am receiving drawings from subs and cannot get their items to show up... AutoCAD says it cannot load the .dbx file... I am not sure if it is old or not compadible to AutoDesk 2013 versions
Here are the details for the CADmep object enablers:
Fabrication CADmep 2013 object enabler (for 2013 products only)
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-fabrication-...
CADmep legacy enabler for AutoCAD 2009-2012 (as *Mike mentions, this version requires manual registration with AutoCAD)
Hope this helps.
Nick
2014 NAVISWORK
UPGRADED FROM AUTOCAD 2013 TO 2014 ALSO THE SAME WITH NAVISWORK AND I ALSO INSTALLED AUTODESK FABRICATION CADMEP 2014 OBJECT ENABLER I HAVE SUB-CONTRACTOR WHO USES CADDUCT SOFTWARE AND I AM NOT ABLE TO SEE THE DUCT IN 2014 NAVIS IT WAS FINE IN 2013 IS THERE ANY PATCHES OUT THERE TO CORRECT THIS PROMBLEM THANKS
Autodesk Fabrication CADmep 2014 Object Enabler - http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-fabrication-...
Autodesk Fabrication CADmep 2013 Object Enabler - http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-fabrication-...
The Fabrication CADmep 2015 object enabler will need to be installed, I'll post a link once released.
Fabrication CADmep 2015 object enabler - http://knowledge.autodesk.com/support/fabrication-products/downloads/caas/downloads/content/autodesk...
