AutoCAD MEP General Discussion
Member
hilmitannous
Message 1 of 6 (4,995 Views)
Burst Command in Autocad MEP 2012
4995 Views, 5 Replies
04-26-2011 12:11 PM
The burst command does not wok in 2012, does anyone know what it changes to?
pendean
Message 2 of 6 (4,974 Views)
Re: Burst Command in Autocad MEP 2012
04-27-2011 11:46 AM in reply to: hilmitannous
Did you remember to install Express Tools?
Do you have any Express Tools installed?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
mustangman6799
Message 3 of 6 (4,767 Views)
06-14-2011 01:46 PM in reply to: hilmitannous
I don't know if this is the "right" answer, but it works.
Just create a new command- (in CUI, on the left side in the Command List area there is a star with a little sun? on it.  This is the new command button.  Click it.)
This will bring up a box with properties you populate to create a new command.  These are my answers (you can cheat off of me.. it's o.k.)
Description (Displays as a tooltip when you hover on the new botton): Blows crap up but not as thoroughly as explode
Extended Help File:
Command Name: Burst
Macro: burst
Tags:
Under Images, select an icon you would like to represent your new button.  I found a bitmap of Mike Tyson's face.  It works.
Hit save and put it on your toolbar or panel somewhere. Also, use point filters.  They're awesome once you add an @ to the macro!
Valued Mentor
Jeffrey_H
Message 4 of 6 (4,744 Views)
06-19-2011 09:21 PM in reply to: mustangman6799
For 2012, 2011 and maybe 2010 I did not have the option to install express tools and had to go to control panel and hit unistall but you do not unistall it then choose add tools or whatever the options is.
You can also find your answers @ TheSwamp
Active Contributor
cadallday
Message 5 of 6 (3,996 Views)
11-18-2011 12:34 PM in reply to: mustangman6799
mustangman -- any chance you could spell out the macro? i can draw but can't program myself out of a paper bag.
would sure appreciate it  --  thanks!
New Member
herb.cadtech
Message 6 of 6 (2,035 Views)
12-12-2012 10:51 AM in reply to: hilmitannous
That woked perfectly! Thanks a lot!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
