The burst command does not wok in 2012, does anyone know what it changes to?
Did you remember to install Express Tools?
Do you have any Express Tools installed?
I don't know if this is the "right" answer, but it works.
Just create a new command- (in CUI, on the left side in the Command List area there is a star with a little sun? on it. This is the new command button. Click it.)
This will bring up a box with properties you populate to create a new command. These are my answers (you can cheat off of me.. it's o.k.)
Description (Displays as a tooltip when you hover on the new botton): Blows crap up but not as thoroughly as explode
Extended Help File:
Command Name: Burst
Macro: burst
Tags:
Under Images, select an icon you would like to represent your new button. I found a bitmap of Mike Tyson's face. It works.
Hit save and put it on your toolbar or panel somewhere. Also, use point filters. They're awesome once you add an @ to the macro!
mustangman -- any chance you could spell out the macro? i can draw but can't program myself out of a paper bag.
would sure appreciate it -- thanks!
