AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Burst Command in Autocad MEP 2012
5 REPLIES 5
5650 Views, 5 Replies
The burst command does not wok in 2012, does anyone know what it changes to?
5 REPLIES 5
pendean
Did you remember to install Express Tools?
Do you have any Express Tools installed?
mustangman6799
I don't know if this is the "right" answer, but it works.
Just create a new command- (in CUI, on the left side in the Command List area there is a star with a little sun? on it.  This is the new command button.  Click it.)
This will bring up a box with properties you populate to create a new command.  These are my answers (you can cheat off of me.. it's o.k.)
Description (Displays as a tooltip when you hover on the new botton): Blows crap up but not as thoroughly as explode
Extended Help File:
Command Name: Burst
Macro: burst
Tags:
Under Images, select an icon you would like to represent your new button.  I found a bitmap of Mike Tyson's face.  It works.
Hit save and put it on your toolbar or panel somewhere. Also, use point filters.  They're awesome once you add an @ to the macro!
in reply to: mustangman6799
For 2012, 2011 and maybe 2010 I did not have the option to install express tools and had to go to control panel and hit unistall but you do not unistall it then choose add tools or whatever the options is.
cadallday
mustangman -- any chance you could spell out the macro? i can draw but can't program myself out of a paper bag.
would sure appreciate it  --  thanks!
That woked perfectly! Thanks a lot!
”Boost
