My build panel used to contain conduit and cable tray buttons, but it now contains duct and pipe buttons. I didn't change anything, this just appeared one day. How can I change it back?
Solved by Keith.Brown. Go to Solution.
I've lost my workspace toggle in the bottom right as well. All I see is "standard" or "medium detail".
Hey Keith using WSCURRENT then typing "electrical" fixed my problem. Thanks alot, I really appreicaiate all the help you provide to this forum.
One more question, but I don't want to start a new thread. I have many projects created in AutoCAD 2012, but our company recently switched to 2013. When I open these 2012 projects in 2013, conduits created in 2012 look phyisically larger than conduits created in 2013 even though they have the same nominal diameter. Moreover, when using 2013 I cannot change the nominal diameter of the conduits created in 2012. Is there a way to correct this?
Again, thanks for the help Keith.
How would I load the 2012 content package into 2013? I'm just learning MEP..
I changed the catalog to 2012 and I'm still unable to change the older version of conduit. I can't even tell if anything changed when I changed catalog.
