AutoCAD MEP General Discussion
Member
0 Kudos
Post 1 of 5
BOMTables
916 Views, 4 Replies
10-11-2012 11:13 AM
I created a BOM from "bomtables", selected the piping and the table is extreamly large becuase it listed each item in it's own row.  Rather than one row for each type with a total quantity.
How do I adjust this so the BOM is not so large?
Product Support
16 Kudos
Post 2 of 5
Re: BOMTables
10-17-2012 10:43 AM in reply to: rabraham
Try BOMTOTALS.  Select and edit the table style.  Hide the Qty column, and any segment length columns.  Once updated, the table should collapse down to one row per diameter segment with a total length.
Hope this helps,
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Support Specialist
Product Support
Valued Mentor
9 Kudos
Post 3 of 5
Re: BOMTables
10-23-2012 01:01 PM in reply to: Joshua.Benoist
I just read this post.... it is new to me... this is native AutoCAD table object... not specifically MEP. How is it reading the MEP properties?
Joshua... Can you get me to some documentation on this?
New Member
0 Kudos
Post 4 of 5
Re: BOMTables
11-27-2012 10:31 AM in reply to: rabraham
I tried Typing in BOMTOTALS and it did not reckognize the comand. What am i doing worn? I am using Autocad MEP 2012
109 Kudos
Post 5 of 5
Re: BOMTables
12-01-2012 10:43 AM in reply to: kstokesdyna
Autocad MEP has a command in it called BOMTABLE.  What it will do is read the information from the parts that you select and create a standard autocad table from it.  The configuration for the table can be edited in the setup xml file. On my machine the xml file is located at C:\ProgramData\Autodesk\MEP 2013\enu\Shared.  Obviously I am using MEP 2013 but you should be able to find your file using that directory structure.  Once there open up the AecbBomTablesConfig.xml file and edit it to your hearts content.  You are able to specifiy which property sets it should read.  Prior to 2013 this was used to total up runs of pipe at different diameters.  With Autocad MEP 2013's ability to do this with Schedules, BOMTABLE has lost a little bit of its appeal.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
