Hi everyone,
Okay so I started up MEP 15 and selected a sheet set template Aecb Sheet (US Imperial Stb).dwt which gives me a model space, Arch A-Arch F. I create my model (2d layout), set my view ports and then I fill in the template with my company info. I want to export at a PDF 8.5 by 11 for a test and after it exports the text on the sides is bloched and the line weight around the template is extremely heavy and I can't edit it because it states read only because I am assuming this template is a block? I have a attached what is happening. Thank you in adavce for the help. P.S Do not mind the big black backwards L on the diagram I just deleted some info for the privacy of the client.
