AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Bitmap Images Disappear
3 REPLIES 3
WICK
363 Views, 3 Replies
I have been running into a problem with my custom toolbuttons. every time I open AutoCAD, my buttons turn into question marks. In earlier releases, they used to turn into smilie faces. I have been able to some way get around this in the past. I cant get these buttons to keep the bitmap images that I have assigned to them. I have all my Icons saved in one folder, I even mapped the folder through the options support file search path. what do I need to do to make these buttons remember the images?
3 REPLIES 3
in reply to: WICK
Edit your MNS extension menu file, go down to the sections in question, make sure your actual bitmap file names are being referenced: unless you do this specifically, AutoCAD always creates temp files instead and forgets where they are... . -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Matt__W
in reply to: WICK
Sounds like you've done everything right. The only things I could suggest is to
1) Open the MNS file in Notepad and verify what icon is being used. If need be, change the text to reflect your icon (*.BMP file).
2) Delete the MNC and MNR files associated with that menu and let ACAD recompile the MNS file.
Hope this helps!
~ Matt W
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
WICK
in reply to: WICK
I went through my mns file and edited the file to the proper bmp files. I noticed that most of my custom buttons had the bmp's listed twice within the line, while others had the bmp listed once followed by a RCDATA...
EXAMPLE:
ID_UserButton_8 [_Button("External Reference", "XREF.bmp", "XREF.bmp")]^C^C_xref
ID_UserButton_0 [_Button("Device Count", "BLOCK-COUNT.bmp", "RCDATA_16_BLANK")]^C^Cvbaload;vbarun;
My question is, should I change the RCDATA text to match the bmp file name?
”Boost
