AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Batch Plot
2 REPLIES 2
Martin Stone
514 Views, 2 Replies
Batch Plot
I'm using AutoCAD MEP 2010 x64 bit on Windows 7.
I recently had my PC upgraded at work. I have just gone to use the batch plot utility and it doesn't work. I'm trying to plot about 30 DWGs to PDF but when I press Publish the dialogue box closes & nothing happens. It was working fine before the PC upgrade. I was wondering if it is to do with the x64 bit or maybe Windows 7 (I was on Vista before).
Tags (2)
2 REPLIES 2
A bit of a thread revival. I am now using Acad MEP 2015 on Windows 8.1 x64 and I still have the same problem.
I go to Publish.
Set 'Publish to:' to PDF.
Bring in the drawings I want to print.
Hit the 'Publish' button and the dialog box disappears and nothing else happens.
smbrennan
in reply to: Martin Stone
First steps, are you sure nothing is happening? Could it be a possibility that you are publishing in the background, and PDFs are being sent to you 'Documents' folder by default?
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
”Boost
