AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Autodesk Sync
2 REPLIES 2
tony_csogroup
530 Views, 2 Replies
Autodesk Sync
After the update that fixes the issues with Autodesk Sync, it seems to now be working correctly...
... but I'm having a problem using it with MEP.
I use two profiles. The standard AutoCAD profile (with no MEP content) and the AutoCAD MEP (UK) profile.
Here’s the problem... when I use the MEP (UK) profile, it syncs my setting accordingly. But when I use the standard AutoCAD profile, it starts to upload all the MEP profile changes and I get all the incorrect ribbons icons back. This also seems to happen the other way round. So if I have two copies of AutoCAD open (using both profiles) it seems to sync all day!
My conclusion is that syncing settings is NOT profile specific, but a global thing. Which can’t be right… can it?
Any thoughts?
Anthony Russell
LinkedIn
2 REPLIES 2
I wonder if it's a "per application" thing? While both ACA & AMEP have "AutoCAD profile" it's not quite the same as plain autocad & have to wonder if Sync Settings hasn't allowed for this?
Robin
Autodesk AEC Collection 2020 - PC: HP Z6 | Win 10 64 | Xeon 3014 | 64 GB ram | Quadro P5000 - Tablet: Surface 3 Pro i5-4300u | Win 10 Ent 1703 64 | 8GB ram - Phone: Samsung S21 Ultra | Android 11
RobiNZ CAD Blog | LinkedIn
Shawn_Niles
in reply to: robincapperw
Autodesk is aware of this issue and we are working towards a long term resolution. Thank you for your patience in the meantime, and we do apologize for any inconvenience this is causing you.
Shawn Niles
”Boost
