AutoCAD MEP General Discussion
Active Member
mike29787
Message 1 of 5 (2,342 Views)
AutoCad MEP2013 Express Tools
2342 Views, 4 Replies
10-02-2012 04:49 AM
I have been trying to load the express tools to no avail....I used menuload and loaded the express cui file, checked to make sure it was in the support path, dragged and dropped them in the cui menu, "express" shows up in the toolbar but all the commands are "unknown" and the icons appear as bubbles with question marks, in addition when I go to the program manager and unistall/repair and add tools there is no express box to check? Looking for some help thanks...
Keith.Brown
Message 2 of 5 (2,333 Views)
Re: AutoCad MEP2013 Express Tools
10-02-2012 11:06 AM in reply to: mike29787
Did you go into your control panel and go into uninstall a program and from there choose autocad mep?  This will start the setup program again and from there you can choose Add/Remove Features and then choose to check/uncheck Express Tools along with other items.  You might have to undo everything that you did before to make sure that this works correctly.  But this should be the method that is used when installing or uninstalling express tools.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Active Member
mike29787
Message 3 of 5 (2,326 Views)
10-03-2012 07:50 AM in reply to: mike29787
Thanks, I attempted that also but when I select AutoCad MEP2013, in the checkboxes is only the uints, and language there is no "checkbox" for expres tools??
Keith.Brown
Message 4 of 5 (2,306 Views)
10-05-2012 09:41 AM in reply to: mike29787
You are almost there.  :-) Choose the Units and Languages that you want.  It will probably not change from what you have selected.  And then hit NEXT.  The next screen is where you will find the checkbox for express tools.
New Member
pnrreddy
Message 5 of 5 (1,446 Views)
03-08-2013 01:38 PM in reply to: mike29787
I have installed 2013 MEP express tools but some of the commands (txt2mtxt etc) do not work; Supposedly  Autocad is working on a fix. Does anybody know if there has been a fix yet? meanwhile can somebody send LISp routine code to autoload ARX files located in the express folder?
Thanks.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
