That is a very nice set of features. I'd be most interested in the
parametric parts, fittings and the auto offset/transition by selecting
two connectors. With that being said, I'd like to go through the full
functionality to see the full potential.
Have you decided how this application will be distributed, the price,
release date, etc.? How will upgrades be handled?
DotNetDude wrote:
> My team and I have been working on an AutoCAD MEP add on application since ABS 2004, and I am happy to report that the beta version is in it's final stages of development.
> Some features include:
> - Complete duct catalog built from the ground up based on actual duct manufacturer's catalogs
> Transition fittings that offset in any direction
> Offset fittings that offset in any direction
> Taps with dampers
> Inline dampers
> Mitered duct
> Low loss, conical, and specialty fittings
> All fabrication dimensional data included in the Size Name
> Parametric roof tops, split systems, fans, inline equipment, and moreā¦
> - Systems Definitions additions
> User defined default parts by system and shape
> User defined joint lengths and insulation application by system and shape
> Autolayout defaults including "Use Takeoff / Use Tee" by system and shape
> User defined default data attached by system and shape including:
> Single / Double Wall
> Material
> Water Gauge
> Seams (Pittsburgh, Snap Lock, Welded, User Defined...)
> Connectors (TDF / TDC, Duct Mate, S&D, Welded, User Defined...)
> - Intelligent Part Numbering
> Identical parts get the same part number
> Part numbers attached to the top of parts for 3D views
> Selective numbering
> User defined part numbering options
> Parts thoroughly sorted before numbering
> (Rectangular, Single Wall, Galvanized, 2" WG, Pittsburgh, Duct Mate, 1-1/2" Liner duct will be numbered together in a manner that keeps Fabrication / Installation schedules streamlined and intuitive)
> - Automated duct linear / square feet totals
> - Automatically insert transition / offset fitting by clicking two duct connectors
> - All from the convenience of a fully integrated, multi-tabbed Tool Palette with it's own "Properties" tab for editing the data mentioned above.
> In the future we hope to offer Plumbing, Electrical and Metric versions with similar features. I thought I would throw this out there to see what the community thinks. Any comments or suggestions are welcome and appreciated.
