AutoCAD MEP General Discussion
New Member
eciadam
Message 1 of 4 (1,225 Views)
AutoCAD MEP & Quickpen issue
1225 Views, 3 Replies
07-15-2010 05:03 AM
I am working with a contractor who is using quickpen 2010 to model plumbing. I am using AutoCAD MEP 2011. When i xref in the plumbing model i have a couple of issues:
1. the plumbing model will not render into a solid. it stays wire frame.
2. i can not snap to the objects of the plumbing model (for instance to ID the elevations). The model seems to come in as proxy object.
One way around the snapping issue is to explode the model before 'xref'ing it into my drawings. however this obviously does not solve the rendering problem. Does anyone have a solution for this?
I've tried to install a couple of quickpen viewers but with no luck.
perhaps this link will help in obtaining the proper object enabler for your system.
http://www.quickpen.com/index.php/PD3D™-Viewers/
Fred Edelmaier
FJE Enterprises
www.fjeenterprises.com
Distinguished Contributor
joeself
Message 2 of 4 (1,219 Views)
Re: AutoCAD MEP & Quickpen issue
07-15-2010 09:38 AM in reply to: eciadam
Do you need object enablers for Quickpen objects?
New Member
eciadam
Message 3 of 4 (1,215 Views)
07-15-2010 10:27 AM in reply to: eciadam
i havent tried any object enablers for quickpen. Do you know where i can find it?
New Member
mail
Message 4 of 4 (663 Views)
08-04-2012 08:18 PM in reply to: eciadam
Fred Edelmaier
FJE Enterprises
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
