Is there any way to download AutoCAD MEP 2014 trial version?
Unfortunately I work on Windows XP so MEP 2015 is not available for me at this moment..
Solved by DarrenP. Go to Solution.
you can download from here:
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Autocad Products>Autocad MEP
Please accept as a solution if this fully resolves the issue
DarrenP
this version isn’t supported by autodesk anymore
you can longer download anymore
DarrenP
