AutoCAD MEP General Discussion
Valued Contributor
mjmpe
Message 1 of 2 (241 Views)
AUTOCAD MEP 2013
241 Views, 1 Replies
12-29-2012 06:39 AM
How do I get my properties box back up on my screen, I was setting up my drwg and I hit autohide on the properties box, I was trying to put it on the side, now I can't get it back.
thanks
Keith.Brown
Message 2 of 2 (215 Views)
Re: AUTOCAD MEP 2013
12-31-2012 08:37 AM in reply to: mjmpe
You can right click anywhere in your drawing area and select properties way down at the bottom or you can just type PROPERTIES at the command line.  If it is still not showing then it is probably on a second monitor or off of the viewable screen area.  If this is the case, I have had success bringing it back into the viewable area by changing workspace or my profile.  Both of those options store the locations of the palette and by changing to another one you are effective resetting your palette.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
