Please fix the reducing elbow option in mep 2013. If this opton is selected while drawing pipe, every bend you try to make mep 2013 thinks it should be a reducing elbow even if you haven't selected a different pipe diameter. The same thing will happen if you try to draw a branch off of a pipe run, the choose a part dialog appears with no branch fitting options only reducing elbows of multible part types. Mep 2012 draws pipe perfectly with the reducing elbow option selected and will use the reducing elbow when pipe diameters are changed. I hope this could be a hot fix I sure would hate to have to wait for the first service pack to correct this issue.
I think it expects you to change the property to not use a reducing elbow after you draw the reducing elbow. This setting is how the software differentiates between your desire to put in a straight transition, a straight elbow plus transition fitting, or a single reducing elbow. It is designed so that you set it back to plain elbow when not roughing in a reducing elbow. You are defining exactly what you want. Do you want a reducing elbow or a plain elbow? I can see a need to default to plain elbow. So when you want a reducing elbow, you change the setting and once drawn, it changes back to plain. Maybe some setting to define a default preference in Pipe Preferences. Log a wish request at the feedback site:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
As a plumbing designer I us 4" x 3" reducing closet bends quite often, I have been able to work around this 2013 modification that differs from the mep 2012 release, but it has slowed down my drawing speed considerably having to access the properties pallet every time I use a reducing closet bend. I'm still hoping this may be just an oversight and will soon function like mep 2012.
It does behave different between 2012 and 2013. I see that now, thank you for bringing it to our attention. It is now in the developers hands. They are aware, and are working to address the change in behavior.
Joshua
This thread was back in 2012... 2014 is out and as far as I can tell, it's still not been fixed. Is there a fix, patch, etc? It's cumbersome to have to change piping preferences just to switch between a straight elbow and a reducing elbow.
Mep 2015 is out and running and still no fix to the reducing elbow. My hopes for this fix have exhausted.
Auto Cad MEP 2016 is out and the reducing elbow option is finally fixed. Only took three years. I'm just glad it's finally fixed.
We were excited about seeing that option fixed. However, when the "use if needed" is selected, the auto connect function does not work properly if two pipes are at different elevations, such as a higher pipe connecting to a lower pipe with a take-off. If the two pipes are at the same elevation, then the take-off will work.
