AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
AutoCAD MEP 2013 - Layers
3 REPLIES 3
892 Views, 3 Replies
I have created a new drawing template file will my custom piping system definitions and associated layers / colors.  When I begin drawings however, all piping is put on the standard layer.  What am I doing wrong?
3 REPLIES 3
Joshua.Benoist
Did you start your custom template from the MEP default template "Aecb Model (US Imperial CTB).dwt?"
Joshua
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
mlmoore
The issue is because your layer key styles do not have the system layer.  In the style manager for layers go to the layer key styles and add the system layers used for each system definition.  They must match the system layer name exactly.
in reply to: Joshua.Benoist
No - I created my template from an existing drawing.  The layers I have named in the piping system definitions do match the layers that I have listed in my system layers for said drawings.  Still all piping is drawn as standard.
”Boost
