AutoCAD MEP General Discussion
Member
mike
Message 1 of 4 (778 Views)
AutoCAD MEP 2013 Layer Dialog - Layer pane not updating to selected filters
778 Views, 3 Replies
08-31-2012 12:29 AM
I just recently started having a problem with my layer dialog box in MEP 2013.  If I select a layer filter the layer pane does not update to show those filtered layers - it stays on last selected filter.  Even if I close the dialog box and reopen it still displays the last selected filter.  If I close Autocad and reopen sometimes it will change but then at some point it will freeze up the layer pane again.
Does it happen with just one drawing or have you experienced it with any file?  Have you tried a repair from the Windows > Add/Remove Programs utility?
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Product Support
Joshua.Benoist
Message 2 of 4 (750 Views)
Re: AutoCAD MEP 2013 Layer Dialog - Layer pane not updating to selected filters
09-04-2012 06:40 AM in reply to: mike
Joshua
Joshua Benoist, PE
Senior Support Specialist
Product Support
Product Support
Joshua.Benoist
Message 3 of 4 (732 Views)
09-05-2012 02:05 PM in reply to: Joshua.Benoist
Just wanted to follow up.
Joshua
Joshua Benoist, PE
Product Support
New Member
mpluta69
Message 4 of 4 (343 Views)
07-22-2013 11:54 AM in reply to: Joshua.Benoist
Joshua,
I have this issue as well and have never found a solution.  I have tried to repair and that did not help.  Do you have any other fixes?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
