AutoCAD MEP General Discussion
Product Support
Joshua.Benoist
Message 11 of 18 (412 Views)
Re: AutoCAD MEP 2013 Cui Menus - I'm so confused
08-22-2012 12:56 PM in reply to: Joshua.Benoist
I consulted with my team.  We added a sub-menu in the Osnap menu with a new tool and it's working.  You mentioned setting up 2013 as an Enterprise CUI instead of a Main CUI.  You know the Enterprise CUI's are locked, right?  Have you tried it with set as a Main CUI in 2013?
Joshua
Joshua Benoist, PE
Senior Support Specialist
Product Support
Product Support
Joshua.Benoist
Message 12 of 18 (409 Views)
08-22-2012 01:24 PM in reply to: Joshua.Benoist
Do you have the MEP.CUI as the enterprise, or any CUI as an enterprise?  You should set the enterprise cui back to be the Main cui.  Then add the custom sub-menu to it.  Then set it back to enterprise.  See if that helps.
Joshua
Joshua Benoist, PE
Product Support
Product Support
Joshua.Benoist
Message 13 of 18 (386 Views)
08-27-2012 02:05 PM in reply to: Joshua.Benoist
Wanted to follow up and see if the above helped?
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Product Support
Distinguished Contributor ken
ken
Message 14 of 18 (384 Views)
08-27-2012 02:10 PM in reply to: Joshua.Benoist
Sorry I have not tried  your last suggestion, things got crazy here.  I will try to do it tomorrow and I will post back.
Thanks for still sticking with me on this.
Sincerely,
Ken
ken
Message 15 of 18 (377 Views)
08-28-2012 07:15 AM in reply to: ken
Thanks for all the information, it seems to work now.  I have the MEP.cuix as the Enterprise file on the main server and a Custom.cuix as my main.
Now the next question is why wont it keep my screen layout as I left it?  I arranged my Toolbars in some order and turn on the menubar but when I exit and return its all back as originally laid out.
Thanks again for the help I do really appreciate it.
Sincerely,
Ken
Product Support
Joshua.Benoist
Message 16 of 18 (375 Views)
08-28-2012 07:24 AM in reply to: Joshua.Benoist
You probably need to make the toolbar changes before setting an enterprise cui.  Once an enterprise cui is specified, it locks many items down.
Joshua
Joshua Benoist, PE
Product Support
ken
Message 17 of 18 (367 Views)
08-29-2012 08:14 AM in reply to: Joshua.Benoist
Thanks for all the help, all my menus work now and the workspace is staying the same.  The workspace had to be created / saved and set equal to me in order for it to hold.
Thanks again for all the help,
Ken
tedwards
Message 18 of 18 (360 Views)
08-29-2012 10:26 AM in reply to: ken
why don't you load the menus you want, enter RIBBONCLOSE and set MENUBAR to (1). This will give you the format you are looking for.
AutoCAD MEP 2013
Window 7 pro 64 bit
E5440 (8 CPU) ~2.8ghZ
16GB RAM
NVIDIA QUADRO FX 3500 2270MB
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
