AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
AutoCAD MEP 2013 Cui Menus - I'm so confused
17 REPLIES 17
Message 1 of 18
2444 Views, 17 Replies
Ok we have made 2 cui files in the past (Mech and Elec) and we really have never brought them in properly to AutoCAD as far as I'm concerned.  We are jumping from 2010 to 2013 and would like to incorporate them in to 2013 properly. It seems to me that 2013 has gotten rid of all the menus in the menubar for ribbons.
This is what we are looking to achieve:
We would like to have a full set of menus in the menubar
We would like to have our custom CUI's loaded
We would like to have a custom entry called TOOLS in the OSNAP menu for Shift Right-Click
Lastly we would like for the Workspaces to hold for each user
What is the proper way for this to happen?  We always made a custom.cuix for the main customization option and went to an MEP.cuix in the Enterprise customization option but this does not seem to work in 2013 for us.
Thanks for any help you can provide,
Rodeoboy
17 REPLIES 17
Message 2 of 18
Joshua.Benoist
We no longer make menus and toolbars for AutoCAD MEP in favor of the Ribbon.  I can send you the 2010 versions that you can transfer into the CUI from the transfer tab of the CUI editor.  See attached zip file for the 2010 menus.  Workspaces have a setting to remember changes or not remember changes.  Set it to not remember changes once you have selected the desired workspace for each user.  This is good feedback, that should be posted at the feedback site.  Here's a link.
Hope this helps,
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Message 3 of 18
Thanks for the reply, I now have the menus loaded and working.  However there was tweak that we did with the Shortcut menus where we places some custom "Tools" so all we had to do was Shift Right-click to access the.  We placed them under the "Object Snap Cursor Menu"  but I can't seem to get that to work.
Any ideas?
Thanks in advance.
Ken
Message 4 of 18
Joshua.Benoist
Can you capture us a photo of the CUI dialog and expected result?
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 5 of 18
in reply to: Joshua.Benoist
OK I am attaching a screen shot from a 2010 station that shows the (2) custom CUI files (Mech.cuix and Elec.cuix) loaded which give us the 4 additional menus (Mech / Plumb / Elect / Ltg Cuts).  As well as it shows the modification to the Osnap Quck launch menu for when you use Shift + Right-Click.   What it does not show is all the AutoCAD 2010 Ribbons cause we could never get them to load with the custom menus but I would like for the 2013 to allow us to use the ribbons.  So any I am attaching to PDFs hopefully they wont be to grainy.
Ken
Message 6 of 18
Joshua.Benoist
Two posts above, you said "we cannot get "That" to work.""  What does "that" mean?  The shift + right-click access, or the leader tools themselves?
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 7 of 18
The Osnap menu shows up like Autodesk originally as had it, not with my Added TOOLS section.  So I am not sure where the OSNAP menu is being pulled from and where I should insert my TOOLS customization.
I have attached what my 2013 looks like.
Sincerely,
Ken
Message 8 of 18
Joshua.Benoist
It looks like you transferred in the custom tools and added it to the Osnap menu, but did you turn it on in the workspace?
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 9 of 18
It doesn't allow me to add it to the Workspace.  I can't drag and drop nor add a checkmark in the box when the workspace customization mode is active.
Ken
Message 10 of 18
Joshua.Benoist
Ken,
Nothing is coming to mind but if I think of something I'll not hesitate.  There is two sides to your coin, the CUI side and the customized commands side.  Either side could be preventing this from working.
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 11 of 18
I consulted with my team.  We added a sub-menu in the Osnap menu with a new tool and it's working.  You mentioned setting up 2013 as an Enterprise CUI instead of a Main CUI.  You know the Enterprise CUI's are locked, right?  Have you tried it with set as a Main CUI in 2013?
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 12 of 18
Do you have the MEP.CUI as the enterprise, or any CUI as an enterprise?  You should set the enterprise cui back to be the Main cui.  Then add the custom sub-menu to it.  Then set it back to enterprise.  See if that helps.
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 13 of 18
Wanted to follow up and see if the above helped?
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 14 of 18
Sorry I have not tried  your last suggestion, things got crazy here.  I will try to do it tomorrow and I will post back.
Thanks for still sticking with me on this.
Sincerely,
Ken
Message 15 of 18
Thanks for all the information, it seems to work now.  I have the MEP.cuix as the Enterprise file on the main server and a Custom.cuix as my main.
Now the next question is why wont it keep my screen layout as I left it?  I arranged my Toolbars in some order and turn on the menubar but when I exit and return its all back as originally laid out.
Thanks again for the help I do really appreciate it.
Sincerely,
Ken
Message 16 of 18
You probably need to make the toolbar changes before setting an enterprise cui.  Once an enterprise cui is specified, it locks many items down.
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Message 17 of 18
Thanks for all the help, all my menus work now and the workspace is staying the same.  The workspace had to be created / saved and set equal to me in order for it to hold.
Thanks again for all the help,
Ken
Message 18 of 18
why don't you load the menus you want, enter RIBBONCLOSE and set MENUBAR to (1). This will give you the format you are looking for.
”Boost
