AutoCAD MEP General Discussion
blizt85
Message 1 of 2 (702 Views)
AutoCAD MEP 2012 and 2013 !!! PROBLEM !!!
702 Views, 1 Replies
06-11-2012 07:10 AM
In my office, we are about 5-6 working on a big project using AutCAD MEP 2012. Now over the middle of the week one of those station got change and my computer tech installed AutoCAD MEP 2013. I am the CAD Manager of this place and i wasent told that he was changed. Last friday the technicien working with the AutoCAD MEP 2013 worked on 4-5 DWG and now those drawings can't be open using the others station without loosing all of the mep related objects ( ducts, diffusers, soo on...) Now we arent rdy to change all of the others stations to AutoCAD MEP 2013 and this project needs to be completed by the end of the week. Is there anything we can do to the others station in other to get it to work with the drawings saved in 2013 ???? (addons or something) ?????
Any helps would be welcome,
Thank you.
Ed
Valued Contributor
jcleghorn
Message 2 of 2 (663 Views)
Re: AutoCAD MEP 2012 and 2013 !!! PROBLEM !!!
06-12-2012 01:58 PM in reply to: blizt85
Heads will role! (My eyes are rolling:smileywink:
It's obvious objects loose their functionality when going to a down version, in fact, the objects are just lost when converting from 13 to 12 (10-12). You can save the 3d objects as solids if that helps. If you export in plan view from 13 to version 10, all objects are flattened. If you export from isometric view from 13 to 10, at least you can have the objects converted to 3d solids. Hope that helps.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
