AutoCAD MEP General Discussion
jasimtp
Message 1 of 3 (451 Views)
Accepted Solution
AutoCAD MEP 2011-64 Error
451 Views, 2 Replies
06-25-2013 04:57 AM
We have an AutoCAD issue which showing following error message while trying to start  the AutoCAD MEP 2011-64
Unable to run AutoCAD. This may be due to one of the following reasons:
1) This version of AutoCAD was not installed properly. In this case, you may wish to reinstall AutoCAD.
2) You do not have sufficient rights to run AutoCAD.
Its a network licensed version.
OS : Windows 7 64 bit
 (Hardware & software meets the requirement as per AutoDesk listed).
Dot Net Version : Microsoft .NET Framework 4
Have tried several 3 times of installation in the same machine with full admin rights.
How do we resolve this issue ?
Product Support
david.lau
Message 2 of 3 (428 Views)
jasimtp
Message 3 of 3 (404 Views)
Re: AutoCAD MEP 2011-64 Error
06-30-2013 12:57 AM in reply to: jasimtp
Thanks David Lau
Just re-applied the Service Pack 1 for Windows 7-64bit  and the issue was resolved
Best Regards
Jasim
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
