We have an AutoCAD issue which showing following error message while trying to start the AutoCAD MEP 2011-64
Unable to run AutoCAD. This may be due to one of the following reasons:
1) This version of AutoCAD was not installed properly. In this case, you may wish to reinstall AutoCAD.
2) You do not have sufficient rights to run AutoCAD.
Its a network licensed version.
OS : Windows 7 64 bit
(Hardware & software meets the requirement as per AutoDesk listed).
Dot Net Version : Microsoft .NET Framework 4
Have tried several 3 times of installation in the same machine with full admin rights.
How do we resolve this issue ?
Solved by david.lau. Go to Solution.
Thanks David Lau
Just re-applied the Service Pack 1 for Windows 7-64bit and the issue was resolved
Best Regards
Jasim
