AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
AutoCAD MEP 2011-64 Error
2 REPLIES 2
jasimtp
739 Views, 2 Replies
We have an AutoCAD issue which showing following error message while trying to start  the AutoCAD MEP 2011-64
Unable to run AutoCAD. This may be due to one of the following reasons:
1) This version of AutoCAD was not installed properly. In this case, you may wish to reinstall AutoCAD.
2) You do not have sufficient rights to run AutoCAD.
Its a network licensed version.
OS : Windows 7 64 bit
 (Hardware & software meets the requirement as per AutoDesk listed).
Dot Net Version : Microsoft .NET Framework 4
Have tried several 3 times of installation in the same machine with full admin rights.
How do we resolve this issue ?
2 REPLIES 2
jasimtp
in reply to: jasimtp
Thanks David Lau
Just re-applied the Service Pack 1 for Windows 7-64bit  and the issue was resolved
Best Regards
Jasim
”Boost
