AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
AutoCAD 2011 MEP Express tools
4 REPLIES 4
nh0mad
6427 Views, 4 Replies
Hi all...
I recently upgraded to MEP 2011. I cannot get express tools to work. I have them pathed to the express folder, and loaded the acetmain.cuix with MENULOAD. I have typed "EXPRESSTOOLS" and "EXPRESSMENU". Both state they have loaded successfully. However, when I try to use any express tools command i get the message "Unknown Command"
Any idea's???
Thanks!
4 REPLIES 4
Mep09Developer
in reply to: nh0mad
I had to Add/Remove Programs to install it from the disk. Then, I simply went into CUI and added Express to my current workspace menu. I did not have to path any folders or specifically load anything with MENULOAD. It works OK for me. Do you have the folder called Express in your AMEP 2011 folder?
yishu_xu
in reply to: nh0mad
Hi
If you have load the express tool menu.
I think you have to customize your workspace (command: CUI) to confirm the express tools checked for the ribbon in this workspace.
see the attachment.
nh0mad
in reply to: nh0mad
Got it...thanks folks!
jedenton
in reply to: nh0mad
what if they are not checked?...no check boxes present??
”Boost
