When you make a parametric part... e.g. MvPart, Fitting, etc. You assign a Type and Subtype values... and apparently you can add Type(s) and Subtype(s) to the list.
From what I am seeing these are visible to the user in AutoCAD MEP in two places... in the Parametric Content Builder and in 'Select a part' dialog box.
(see the attached image)
Can someone show me where this is stored - that I may edit the list?
Solved by Keith.Brown. Go to Solution.
yep... looks right.
I just edited a specific Parametric Part xml file in XML Notepad and regenerated the catalogs.
The list of SubTypes changed acccordingly... so MEP must scan the xml files, as you say, 'in realtime', to build the list.
thanks for you help Keith!
