AutoCAD MEP General Discussion
Product Support
Joshua.Benoist
Message 11 of 19 (1,492 Views)
Re: Area Command in AutoCAD MEP 2013
05-15-2012 09:09 PM in reply to: mahlke.leslye
I noticed in an image that you have the Roombook extension.  One aspect of Roombook is about getting Areas of the rooms.  I reached out to the developers to see if they were aware of any issues.  They are not aware of any issues but are investigating.  I'll let you know if we learn anything.
Joshua Benoist, PE
Senior Support Specialist
Product Support
Product Support
Joshua.Benoist
Message 12 of 19 (1,485 Views)
05-16-2012 12:36 PM in reply to: Joshua.Benoist
We found something that may help.  Your video, on the command line you have only one line of prompt history showing.  So when the AREA command goes to report the AREA you cannot see it.  The command tries to display the total area at the mouse crosshair.  Then when Dynamic Dimensions are enabled, it overrides that pop up at the crosshair and so you end up not observing the Area reported anywhere.
So turn off Dynamic Dimensions down near the Osnap toggle buttons.  On the command line palette, is a wrench symbol containing the command line settings.  In the settings is "Lines of prompt history."  Default value is to have 3 lines.  Let's see if those changes help.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Product Support
Active Member
mahlke.leslye
Message 13 of 19 (1,479 Views)
05-17-2012 07:31 AM in reply to: Joshua.Benoist
Your latest suggestion worked!  Everything is fine now.  Thank you for all your help!  Have a wonderful day!
bjo
New Member
bjo
Message 14 of 19 (1,464 Views)
05-30-2012 04:44 AM in reply to: mahlke.leslye
Try to MOVE the objects closer 0. I tried that on a DWG that I just got and then it worked.
BJ
Kind regards
Bjorn J.
Member
Nor72
Message 15 of 19 (1,359 Views)
11-05-2012 05:34 AM in reply to: Joshua.Benoist
I have the same problem in AutoCad Architecture, in both version 2012 and 2013.
I can't get the area-command to terminate. I do not have dynamic dimensions enabled.
Any solutions yet?
I have overcome the problem by drawing polylines and taken the area out of these, but this is not very satisfactory...
bryarcht
Message 16 of 19 (1,257 Views)
11-21-2012 07:16 AM in reply to: Joshua.Benoist
I have same problem an autocad architecture 2013.  "Distance" command (Measuregeom)  doesn't work either.  Both fine in 2012
bryarcht
Message 17 of 19 (1,255 Views)
Re: Area Command in AutoCAD MEP 2013 - OOOps
11-21-2012 07:18 AM in reply to: bryarcht
Just found earlier note re Command prompt  - everyting now working.
Member
devsankalp
Message 18 of 19 (1,107 Views)
Area Command in AutoCAD LT 2012 is not working
01-23-2013 05:39 AM in reply to: mahlke.leslye
Spoiler
Hi Sir
Spoiler
I have problame with using area command in Autocad LT 2012. The command doesn't let me close the area boundry. it keep asking for " Specify next point". It does not offer a total area quantity.  Does anyone know of a fix for this problem?
New Member
marcio.duarte
Message 19 of 19 (326 Views)
04-14-2014 11:49 AM in reply to: Joshua.Benoist
I'm with the same problem. the area comand never end, when I digit <enter>, it still ask for new point for ever.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
